Discuss Make your mind up! in the UK Electrical Forum area at ElectriciansForums.net
imago
The house I'm working on at the minute has the ground floor lighting wired with switched lives. The live at the hall/landing switch then feeds up into the loft and the first floor is wired loop-in. The front half of the house has the floor joists running side to side across the house, in the back half of the house they run front to back. P****d me right off trying to run cables.
Must be a substantial load bearing wall going across the middle of the house to have that arrangement. Pretty common on the older 3 story houses/buildings....
It's a two storey three bed semi, with nothing particularly unsual in design or layout other than those I mentioned. I've seen them mixed on three or four story houses where they run east - west on the first floor, north - south on the second etc.
The load bearing wall is just 3" brick on the ground floor with a couple of doorways in it which have concrete lintels. All the first floor internal walls are lath and plaster. I found a pre-war Player's cigarette packet in one of them.
Just one of those oddities that keep you on your toes I guess. It'd be boring if they were all the same.
Reply to Make your mind up! in the UK Electrical Forum area at ElectriciansForums.net
Hi folks, Quick query for this still practicing regarding bill payment for a job not complete. My partner recently employed an electrician to do...
