T
test electrical
Testing a school which has had lots of LED upgrades with exor controls. 12 way unit above the suspend ceiling with flex's down to the switches. All the leads were 12/14 meters long with the most of it thrown across the ceilings like spiders wed. I use to have a table of max loads and sizes but can't find it in the Regs.
I sure it shouldn't be more than 3/4m in air but its tie rapped to the ceiling supports and all sorts and there's 15/20 rooms like this. So I have put down BS: 522.8.5 fixed wiring cables not adequately supported C2 in the my Notes so far. Anyone got that table on a pdf or a download link handy.
Not aware there is a maximum length for a flex.
Used to work to 3m for Greg or Click type plugs.
Recently worked on systems which LCMs and flex lengths up to 9m.
Ugly, even my shed looks better :)
From BYB 1mm has 44mV/A/m drop and will be rated at least 10A. Interesting to see if the long runs meet the max loop impedance :)
Some of these LCM systems have overcurrent protection at the LCM.
In some instances the leads are made up and supplied by the manufacturers.
The cable will need to comply for voltage drop, not something to be concerned with on an EICR and fault protection. It is debatable whether flexible cords need fixing in this scenario and are unlikely to be prone to damage. Not sure why you feel this is a C2. Looking crap isn't necessarily dangerous.
I suppose if the ceiling grid gives way under the heat those cables coming down won't make much difference.
Just a couple points that kind of relate to this. the flex for switches are 0v, those boxes are a PITA to program, not cheap either unless you buy the kit yourself and go on the course, they can do damn near anything you want. im a big fan of the one test switch you can stick in the caretakers office and they can test the whole system in one go. also worth noting is that the link the shorts feed and em feed isn't always in place properly, only one bar actually into a terminal, right head scratcher solving that one.
On a different note, we installed fittings a while ago where you just had one ceiling greg then jumped off the fitting to the next. we had i think 16 fitting, all about 2m apart, so atleast 32m of flex, not sure if the manufacturer has a maximum length(obviously max load depening on fitting installed).
Thanks lads I no cost cutting getting bad, but the old 2x2 trunking still in most of the rooms with the the clicks less than 2m away. It's just ---- looking and with the fire regs and the new one in, about removing redundant cables, there's at least two C3 in there and this is new work carried out over the summer. I done some work on the new Alderhey hospital in Liverpool which was modular buildings and this is the future. I have come a long way from MI cables in a shipp yard, before we know it we will be extension lead engineers.
Ya the hand controller is £250+vat and the courses or free at Honeywell at Haydock I don't in Aus as well for the older ones with the MCBs in the controllers when the were call dinalight and Cbus which was a fortune, this new stuff is easy to pick up.
Thanks lads I no cost cutting getting bad, but the old 2x2 trunking still in most of the rooms with the the clicks less than 2m away. It's just **** looking and with the fire regs and the new one in, about removing redundant cables, there's at least two C3 in there and this is new work carried out over the summer. I done some work on the new Alderhey hospital in Liverpool which was modular buildings and this is the future. I have come a long way from MI cables in a shipp yard, before we know it we will be extension lead engineers.
I totally agree it looks like crap, maybe even been guilty of a similar install myself once upon a fast finish friday :flushed:. can't remember the name of the gear we're going to be using on this job but it comes pre programmed, and like th exor kit the pir's/mw detectors plug in through an rj45. used hager gear on the last job, came with a remote that let you program PIR's yourself, time, daylight/lux level etc, was a nifty bit of kit.
It could be Hacel stuff its not bad it comes with a remote with no display just buttons, simple.
max length of a 1.0mm flex
Commercial Electrical Advice
test electrical,
test electrical,
