Discuss Megger 1711 issues in the UK Electrical Forum area at ElectriciansForums.net
Evening - I went to turn on the megger today and was instantly met with a battery flashing symbol and it turned off. So I replaced the batteries with 1.5V Alkaline batteries that were new and the same thing happened! Before I loose it for a week to get repaired has anyone else experienced this?
You could ring Megger technical, found them quite helpful. Whilst it still might need fixing they might be able to diagnose.
Guy called Ian Bedsted, or something like that, is their top guru.
The Megger is not the rechargeable one, is it? as if you change the rechargeable batteries for standard ones you have to get it recalibrated.
in Somerset, a megger needs recharging with scrumpy. you just dip the leads in a pint for a few minutes. the Megger goes "hic", then you can drink the rest.
Reply to Megger 1711 issues in the UK Electrical Forum area at ElectriciansForums.net
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Good Afternoon All, I moved into a flat around 2 months ago. A few times only (maybe four times in the two months) I've turned on the kitchen...
Hi Guys, Had a call out today about an odd issue with a newish Creda DT storage heater. Basically.. Storage heaters were installed in one flat...
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
