J
J&M Electrical
Hi all,
Does anybody know where i could 1 of these in 30A? Haven't tried the wholesaler as they were closed today but i doubt they will have 1.
which way are the blades, are they parallel to the longer side?
edit.just seen the other pic. the ones i have are no good to you.
I know, but its either that or a new consumer unit, which is currently in a 300mm base unit, and my shoulders are a lot wider than 300mm so it would be a pig of a job to change.
hi there if you need any more of these breakers i can help you out,regards john.
J&M Electrical,
johnhainsby,
