Discuss metal capping not needed according to 17th in the Electricians' Talk area at ElectriciansForums.net
Is metal capping required on a new installation in a house to protect the cables if a rcd is used ? According to two lads who i work with have done there 17th ed last week it is not needed so is it only for protexting cables while been plastered ?
It is not required. Favoured,specified,preferred,but not required. Careful plasterers negate its use...:icon12:
As already said, never required but often used.
It cannot be used as mechanical protection for the cables if not RCD protected and buried less than 50mm
if someone was to bang a nail the capping wont help. but it will make extracting the cable for repair much harder.
i`m filling my chases with some bonding coat, no cables on show when plasterer comes do his job, no problems later.
capping is pointless really, but is something most electricians like myself like to do.
i thought there was once a reg, for reasonable protection from the plasterers trowel.
I always thought it was a rule of thumb or best practice, If the width of the chase is greater than 3/4 of the width of the plasters trowel capping is needed???
It would be wise to use plastic capping on bare inners leafs that are going to be floated. It keeps the cables tidy and together (if there is more than one) and gives enough protection against a trowel, its common sense really.
Well I have heard it all now, I think the trainee section should snap this fella up sharpish not!!
whats wrong with putting a bit of conduit in so you can actually get the wires pulled in/out without bashing the house into submission?
just a thought.
We always install capping when we wire in singles however.
Omg fellas. Really? Sometimes it is too easy on here.
Bad move. Two options here, either you are making a genuine statement and are clueless about installation techniques or you're making false statements which means you're trolling. Either way you're on thin ice so don't do it again.
Please be warned!!
Threads and posts get indexed by search engines and misleading statements like this end up carrying weight in Google search results because they supposedly come from professional electricians. If you want to start some banter keep it in the Chit Chat forum where it belongs not in the Electrical forums. Also if there's threads closed and posts deleted and your trolling is the cause of it then you'll be shown the door.
just a thought.
And how exactly do you propose to hide a bloody great lump of metal conduit?
Obviously plastic oval conduit is a different thing entirely but you're still cutting a chase.
just a thought.
Well thats the beauty of the oval tube.
i find capping easier to fix however, and keeps cables neat and tidy and secure.
Please be warned!!
Please accept my apology. I did not think of it that way. TBH I really thought it was an obvious joke and thought it would be taken as such.
I have edited my post and made it clear why.
let me be clear. This is absolutely not acceptable practice and should never be followed.
Imho it's good practice to keep all chases as slim as possible. To me it's pointless widening a potential 15mm chase for the sake of a pointless bit of capping when there's not a chance in hell of a plasterer's float going anywhere near your cable, bare walls are usually dot and dabbed round my neck of the woods so it's pointless there too, there are alternatives in a commercial setting too.
I just don't like the stuff. If specced I'll happily put it in but I avoid it where ever I can
The way I was taught is to use plastic capping on new walls and oval conduit in chases in existing walls.
There is no sense in cutting chases wider than they need to be just to put capping in, yet I've seen so many people do this.
When we finally got a chasing machine we would cut 24mm wide chases and use 25mm oval, with the aid of a bit of tile batten it would tap into the chase an wedge tight with no need for any further fixing. It made the whole process pretty quick.
How do you guys fix the oval conduit to the wall? I have never used it and tend to use capping on jobs where i don't know the plasterer and when working along side a couple of plasterers i know locally then as Trev said, i prefer and they prefer a small neat chase!
Either a chase slightly narrower than the conduit and put a black on the conduit then give the block a good tap, or a couple of capping nails either side of the pipe, or for the narrower oval then a 2.5mm T&E clip or two works.
Interesting, how much is a length of oval then and what sizes does it come in? Might buy some tomorrow and give it a try.
Middleton Electrical Services has never needed to rewire a drop but you never know it may happen at some point so i think i may give these oval shenanigans a whirl!
I don't do domestic work so it's not a big deal but I've never seen oval conduit, I don't think it's available locally. Is it fairly new in the UK or has it been around a while?
Interesting to see how others do it. We go to the effort of drilling, plugging and fixing the oval to the wall with galvanised steel band on new builds and existing properties
This side of the pond its 20mm conduit that's generally used, chased into the wall of course. You'd get some strange looks if you turned up with capping or just clipped them into the track.
Either wedge it in or a little bit of bonding will do the trick in a hell of a lot less time
Interesting to see how others do it. We go to the effort of drilling, plugging and fixing the oval to the wall with galvanised steel band on. Ew builds and existing.
i guess others work as tight to the regs as possible to save time and money. if you dont fit capping and use clips its a massive time saving as well as a cash saving of not buying the stuff,
its understandable.
my working practice includes pointless waste of time capping
its understandable.
I've found oval conduit to be quicker than clipping in to chases. I use capping on new/unplastered walls.
There's no sense using capping in chases as you have to make the chases so much wider.
Reply to metal capping not needed according to 17th in the Electricians' Talk area at ElectriciansForums.net
I have a two metre length of 2.5mm T&E running from the loft to a spur under galvanised metal capping (installed during building). Its needs...
Hi, I have a book on domestic wiring which says that everywhere there is a change in current carrying capacity along a circuit there must be some...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
