Discuss Meter tail length in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
W
weston
Hi All,
i'm sure this has been discussed before, but what would you suggest the longest length of meter tails should be.
I know I should ask the distributor, but I am looking for a general view.
Thanks in advance
Weston
Some allow 3 meters if the meter is on the inside and 4 if its in a cavity box.
It either case, anymore than that will require a switch fuse and they are a pain in the ---.
When I did my suitability test for 2391 they asked this . Can't remember what I put but it was a lot more than the desired "Not more than 5M". Don't know wether this is a local supply reg.
Its down to the local DNO to advise.
Figures i gave were a 'general' rule.
Reply to Meter tail length in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi folks, I have recently had a 5kW Solis inverter and 15kW/hr of batteries installed. Everything is working fine, but I have some concerns about...
Firstly, please go easy as I'm still a trainee! Working on my L3 2365 I'm having trouble understanding the rationale behind adiabatics...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hi, Ignoring the appauling conductor terminations which I found, in the background of the photo you can see a really odd neutral tail terminated...
Hi, I was hoping someone with a little more insight might be able to shed some light on a potential issue I have, as I can't seem to find another...
7K
