The Henley block and its derivatives are very much a UK thing, not surprising as the generic name comes from a UK company (W.T. Henley's Telegraph Works.) The original product is branded either Henley or AEI, there were equivalents by Lucy etc, and of course lots of modern copies from overseas.
We haven't been so much into the line-tap idea for this application, it's more common in other countries. The advantage being that the main run of conductor is unbroken so that only the current taken by the tap cable actually flows through the connector. Although, curiously, our UK-specific round phenolic junction boxes with slotted terminals were originally designed with that in mind, e.g. with a 30A 3-terminal box you can spur off a ring without breaking the ring conductors provided you are happy with tape on the main run CPC instead of sleeving.
I use Legrand screw-down line taps as a handy problem solver, e.g. Line tap - non-shear - with feet - capacity per tap 2x16 mm² - hexagonal head - https://www.legrand.com/ecatalogue/034042-line-tap-non-shear-with.html
They are available in a range of sizes, can accommodate a selection of different conductor types and clamp them very tightly without damage. Obviously where IP is important an enclosure is needed but it's not hard to arrange an unbroken slotted path through a box.
Another device I quite like although don't actually use is the Russian «ореx» i.e. nutshell, which clamps the conductors separately between plates a bit like a flat busbar joint and then encloses them between the two half-shells. Pics some way down this page: Russian 'nut' tap connectors
It strikes me that it should be hard to device something along the lines of a Henley, but which allows the insertion of an uncut main run - just strip the insulation. ISTR there are joints (designed to go into potted joints tapping off a street distribution cable ?) where one part is U shaped with grooves that a bar slides into to make it closed - and then the clamp screws can be tightened.
Handy for some things, recently used them to attach SPD to some 25mm tri-rated cables. Didn't realise Legrand also make them.
They look good, reminds me a lot of the clamping plates used to cross-join lightning conductor tapes.
