Strain relief is required when joining cables in lofts, under floors etc. because someone can knock/move the cables and cause them to become loose. However this strain relief can be provided by clipping the cables to joists, and fixing the JB to the joist. If the JB is floating, ie. above chucked above a ceiling, in a void, etc. then it must have strain relief provided. Daz
Well, if the cable was embedded in a masonry/plastered wall just wondering how an enclosure would help or be practical? How are you going to gain any slack in such circumstances??
I just think it's better to be enclosed if at all possible,no chance of the repair getting soaked when filled in for one thing, generally I'd use a very small IP rated enclosure obviously only if some slack can be gained though. If the cable in question was in oval conduit or even flat capping you can generally get a little spare cable from above.
Yes good point. I once managed to pull an entire new length in when the cable in question was in capping. Modern 2.5mm seems to be a bit slimmer than that of a few years ago.
