Discuss Milwaukee M18 Fuel! in the Electrical Tools and Products area at ElectriciansForums.net
I have a couple of Milwaukee 18V tools but the M18FID2 is probably the most useful thing I have bought. It really does a great job with the Armeg style holes saws for 20mm/25mm holes and the hex-shank drill bits make it simple and quick for most small holes in wood or metal.
A friend's son has trained as a mechanic and he had a very neat 90-deg 3/8" driver in their 12V range that I really wanted, but actually have little use for!
Apparently there is a quieter hydraulic version of that 1/4" hex impact driver that might be more useful for the smaller work I generally do, but as no sign of mine failing that is going to have to wait.
I have one of those and the 12v angled impact driver in 3/8 drive, they are both excellent tools. I do some mechanical installations and have found them most useful. Also great for working on vehicles, they definitely save the spanner rash on your nuckles:p
Ok, I'm a DeWalt guy and have found their stuff very good over the years. however, I am not a heavy, daily user. It's clear thatmanufacturers have different quality in their ranges, so one drill at the cheaper end may be pretty poor compared with their top-end offering.
However, just to throw another range into the mix, at the Men's Shed charity where i do some work, we received a donation of a set of Ridgid cordless power tools and they are built like the proverbial tanks. One member sourced spare batteires while in Canada as they are not easy to get in UK. We run DeWalt in the Shed in the main, but it is the Ridgid ones that get grabbed first for any project.
Another thumbs up for Milwaukee Fuel. I do quite a bit of oak timber framing and I need tools that will cut big holes in oak and drive temporary timberfix bolts. I've had 18v Mil Fuel drill and impact driver for 7 years. They have done a lot of work and I am still on the original 5aH batteries. Had to have the impact driver repaired after a slight dropping incident (don't ask) and bought an 18V surge with 5aH as well. It's different - not necessarily better. We've been so impressed my son has recently bought the same set. I use Festool gear too but see no reason to spend crazy amount extra on their drills and drivers (though I do have the super hand 12v drill unit which is great for fitting work).
I bought the kit! Milwaukee M18FPP2A2-502X Twin Pack 2-18v-5Ah REDLITHIUM Batteries 2pce - https://www.powertoolsuk.co.uk/milwaukee-m18fpp2a2-502x-twin-pack.html?utm_source=google&utm_medium=cpc&utm_campaign=18129209029&utm_content=&utm_term=&gad_source=1&gclid=CjwKCAjw17qvBhBrEiwA1rU9wzoNC440PERJ1VXHjyAJ5Ns8JfSPg3y01Zn0dF0mT_B3SHwkLDRWnxoCN-EQAvD_BwE
They had one set left at a toolstation nearish me for £279. Bargain!
Everyone needs 2 impact drivers and 4 combi drills. :D
In fact, I'm considering relegating the makita kit (slowly) to the shed and (slowly) buying more Milwaukee for the van.
How important is torque for the heavy duty timber drilling or what torque do you need
I bought a 300 nM wrench and Bosch speed cut bits but never used the setup yet for timber work
I would say it is more about the bits than the torque of the drill. I use high quality Fisch auger bits for drilling out mortices and peg holes and the Milwaukee has no trouble with these. (I prefer to drill the waste out of stopped mortices rather than use my chain morticer in most cases.) Also the Milwaukee clutch does not snatch when it hits a hard section of oak. I also have a heavy duty high torque Makita corded drill, much used by framers, and have to be pretty careful with that as it does not have a slip clutch and is powerful enough to break an arm if the bit jams (never used spade bits in this application!) as the drill then spins instantly. I use that with long auger bits when drilling through large sections for peg holes. I think the Fuel tools are excellent.
Reply to Milwaukee M18 Fuel! in the Electrical Tools and Products area at ElectriciansForums.net
Looking to have a bit of an upgrade of my cordless tools. I'll be sticking with Dewalt as some of it is still in good nick. I find it irritating...
As title. Looking at my next addition - anniversary and crimbo coming up so want to get the pennies saved ahead of time. Currently posses 2...
Does any have a Milwaukee super hawg 18v drill? Been trying multiple ways of drilling joists on new builds over the years. Impact drivers, angle...
5K
I’m looking to sell my Milwaukee Kit. It contains: 1x 18v SDS 1x 18v Combi Drill 2x 5.0ah Batteries 1x Charger 1x Carry Case Collection is from...
  • Locked
5K
