Most people tend to overlook that aspect of the restriction of leads you can swap if it comes to Y-delta.
What restriction? The conductors can be swapped at the MCC after the isolator but before the main contactor or at the motor, the same as if the motor had been wired to start DOL. The only difference being that with YD you need to know what you're doing if you want to change rotation at the motor seing as you have 4 out of 6 conductors to swap instead of 2 out of 3.
