Discuss Modification of 3 phase board in the Commercial Electrical Advice area at ElectriciansForums.net
Hello, wanting to install a new (old) MCCB in an Dorman Smith Loadline board, found a couple online, however, the client ordering the works is not keen on installing old breakers, so they would rather us connect tails onto the busbar stubs where the breaker would usually be, fashion some kind of protective shroud and take the tails on to an enclosure bolted to the side of the board, with a new protective device in. I know this would work, just not sure how I feel about it. Has anyone had a similar situation before?
Funnily enough I saw this a couple of months ago on an old Merlin panel but I am not sure I would be certifying anything like that. You have two choices use a sourced second hand part and you could still run through the second new device although you would have to ensure selectivity or contact Dorman Smith.
Reply to Modification of 3 phase board in the Commercial Electrical Advice area at ElectriciansForums.net
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
Hi Looking at a job currently adding a 3 phase solar installation but the distribution board is full obviously a new board is the best option but...
Hello - hope someone can advise please. I have a recently purchased second hand Myford lathe which has a 3-phase inverter (Siemens Micromaster...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
