Discuss Motor controls, DOL starters etc in the UK Electrical Forum area at ElectriciansForums.net
So that's due to the smaller amount of demand, whereas something drawing more load,the smaller control circuit will have its own protection yes?
It isn't likely to pose a fault issue due to the nature of the wiring and should the coil fail it is such fine wiring it will likely just rupture like a fuse, that is my personal theory by the way?
Learn about connecting a 3 phase starter controlling a single phase motor
and make sure it's a 230v coil.
You could acquire and connect, for the sake of it, but overloads would be pointless with such a motor. O/L push button to test, I suppose......but live working, remember.
I've got a DOL on my rig, next to it is a 3 way 1G switch that will make/break the main live to the motor (1), the neutral (3) or thr hold contact (1-A1).
I get tothe wife to choose a setting and cover the switch, I then troubleshoot it and confirm that I have got the right fault.
Could you take some pictures of how you've wired that please?
Reply to Motor controls, DOL starters etc in the UK Electrical Forum area at ElectriciansForums.net
We are in the process of restoring 4 of a group of 5 Brookhirst DC motor starters from 1936. These are a thing of beauty and the engineering in...
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
I have this motor from my egg rocker which the incubator was old and needed remaking, it’s a synchrononus 4watt motor that turns my plan is to...
Guys I have 2 DOL starters which share the same supply for 2 toilet extract fans I have a selector switch wired up and and a set of auxilliary...
