Discuss Motor starter A1 and A2 coil contacts in the The Welcome Forum area at ElectriciansForums.net
Does it matter which part of the coil power is supplied? (can you reverse polarity)? For example can I put the “hot” current carrying conductor on terminal A2 and leave with a grounded conductor from terminal A1 (assuming power supplieD is 120v.) (what about 24V?) Is there a specific type of load this can or cannot be done with (resistive, inductive, etc) and what are some real life applications of those types of loads. As this is multiple questions in one thread, I hope to receive a lot of really good answers. Thanks in advance!
-jason
Maintenance Electrician/plc tech
Kellogg Co
If the coil terminals are A1 and A2 then polarity is not important whether ac or dc. Some dc coils may be + and - in which case it is polarity biased.
Most AC loads will run fine if supply polarity is reversed but some loads are polarity critical. That said, you should always follow the manufacturers wiring diagram.
What are examples of polarity critical loads?
[automerge]1583963119[/automerge]
The pressure switches are they passive or active?
You could get mixed up with pnp and npn sensors and switches.
What happens in either case?
Reply to Motor starter A1 and A2 coil contacts in the The Welcome Forum area at ElectriciansForums.net
We are in the process of restoring 4 of a group of 5 Brookhirst DC motor starters from 1936. These are a thing of beauty and the engineering in...
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
  • Locked
5K
I bought a fairly antique 20" Monarch bandsaw. It came with a gigantic (~16" diameter) 5HP electric motor. I'm not sure a bandsaw of this size...
