- Reaction score
- 67,285
egggsackkly.So that 's what Pythons "Ministry of silly walks is about" important training for the youth.
Discuss Moving to radials in Kitchens in the UK Electrical Forum area at ElectriciansForums.net
Why 5mm on a ringI've been using 4mm radial more recently but it's not a silver bullet due to C factors mentioned earlier. I've also started putting the washer dryer circuit on a ring - which is effectively 5mm - perfectly balanced and no sockets - just the connection units for both. If using MCBs on 4mm I usually start off with 20A and change it to 32 later but then I get a better idea about what was added - RCBO's a bit more expensive, so you need to be mindful of the cost. I think the next regs will see thermal efficiency on steroids and we'll be running heavier cables at low current.
not me mate.i got no nerves. guy once told me i had the emotional responses of a house brick.
DeletedI've been using 4mm radial more recently but it's not a silver bullet due to C factors mentioned earlier. I've also started putting the washer dryer circuit on a ring - which is effectively 5mm - perfectly balanced and no sockets - just the connection units for both. If using MCBs on 4mm I usually start off with 20A and change it to 32 later but then I get a better idea about what was added - RCBO's a bit more expensive, so you need to be mindful of the cost. I think the next regs will see thermal efficiency on steroids and we'll be running heavier cables at low current.
OvenPersonally if your fed up with ring mains wire radials 2.5 mm off 20 amp mcb...easy
2.8 KW oven, 3kw ish kettle = nuisance tripping.Personally if your fed up with ring mains wire radials 2.5 mm off 20 amp mcb...easy
2.8kw oven, 3kw kettle = nuisance tripping.Personally if your fed up with ring mains wire radials 2.5 mm off 20 amp mcb...easy
Reply to Moving to radials in Kitchens in the UK Electrical Forum area at ElectriciansForums.net
