Discuss Moving to radials in Kitchens in the Electrical Forum area at ElectriciansForums.net
Dishwasher.... Mrs Tel
Coffee maker.... Mrs Tel
Juicer.. ????
Smoothie maker...???
TVs...can't have 'er indoors watching telly i want my dinner.
Plate warmer .... for snowflakes
Steam oven .. she's got a steam iron
Plinth heater..for wimps
second ovens... no room
Instant hot water taps..... shower upstairs,
Juicer.. ????
Luddite!!
Chauvanistic and Proud.
Juicer.. ????
In my house at present smoothie maker AINT GOT ONE
Steam Iron in the cupboard
Fan heater for HID
Hot water Kettle
Tea Coffee Kettle
Plate
warmer who kin needs one
She has a TV what more can I say
Access to fresh air Patio Door Telephone extension
Boiler control near by
Like Tel Chauvinist and proud of it
Kick plate set in two inches so She can get closer to the sink
Kitchen all white to go with the wedding dress
Should I go on? remember the Son is a forum member so perhaps I had better STFU
as my old man used to say..... " i wear the trousers, your mother wears the knickers ".
Correct Tel but a trifle un PC don't you think? I bin taking Snow flake lessons, curtesy of HID
i don't give a monkey's for all this pc shyte. if we'd had it back in 1940, we'd not have gone to war, afraid of offending despots with Charlie Chaplin moustaches .
not me mate.i got no nerves. guy once told me i had the emotional responses of a house brick.
I've been using 4mm radial more recently but it's not a silver bullet due to C factors mentioned earlier. I've also started putting the washer dryer circuit on a ring - which is effectively 5mm - perfectly balanced and no sockets - just the connection units for both. If using MCBs on 4mm I usually start off with 20A and change it to 32 later but then I get a better idea about what was added - RCBO's a bit more expensive, so you need to be mindful of the cost. I think the next regs will see thermal efficiency on steroids and we'll be running heavier cables at low current.
Why 5mm on a ring
Deleted
Why do you not want to run a 32a ring?
the only issue with 4mm radials is the looping in and out of accessories can be tight.
The last kitchen job i done was overkill because the client had not an idea if they wanted 1.2kw kick space heaters etc :
x1 40a circuit for oven
x1 32a ring for all kitchen appliances and adjoining utility room
x1 32a ring for all sockets within the kitchen
over kill but wont get any issues with overloading, plus sometimes 4mm cable on a 32a is a grey area given installation method
put whatever you think is best, more is better than less, cable is the cheapest bit. Kitchens and bathrooms have become a major stage production.
BUT
what about the latest fashion here in New Zealand for 6kw++ induction hobs plus 1 or even 2 ovens?
We don't do ring circuits here in NZ but I would run at least 2 radial 2.5mm circuits around the benches ( for appliances, microwaves, rangehood, usb chargers etc etc) plus a 2.5 circuit to the island bench for the dual dishdrawer, instant hot water as well as a couple of 4mm or 6 mm circuits for the ovens and hobs. Yes there are some up market Kiwi kitchens that have 2 hobs and 2 ovens.
We never put clothes washer/dryers in the kitchen, they go in either the laundry or laundry alcove in the double or treble garage.
Oh and here in NZ 25amp breakers are as common as muck
Reply to Moving to radials in Kitchens in the Electrical Forum area at ElectriciansForums.net
