H
hey-hey-my-my
Good morning,
I'm on the road year round in a motorhome with two 100w solar panels (soon to be doubled) charging a 260ah AGM battery via a 20a MPPT charge controller. I also hook up a 30a multi stage mains charger about once a week to properly charge the battery.
I'd like to get the most out of my solar setup. On the material side it's as good as can be: wire gauges & distances, fuses/breakers and voltage are all set up correctly.
On the software side however, there is room for improvement, given that there's no AGM charging profile in the charge controller, only FLA (which forces a monthly desulphation cycle) and GEL (charging voltage not high enough). To this end I've purchased a USB to COM cable which allows me to configure a custom charging profile.
Could you please take a look at my settings below and confirm they're OK for daily, cyclic use with an AGM battery?
I'm hesitant as I've heard of some people setting absorption voltage to the same as float (effectively skipping absorption stage) in order to maximise the daily hours spent in float mode, and to avoid overcharging their AGM battery (the battery being constantly under load, it's hard for the charge controller to estimate DOD).
Considering the battery gets a proper mains charge cycle about once a week, would it be a good idea for me to do this? Any insights would be much appreciated!
Cheers!
| Current settings |
| Absorption charging voltage 14.7 Float charging voltage 13.8 Absorption duration (mins) 120 (see attached image for full settings. N.B. boost = absorption) |
Cheers!
