Someone before me went round and replace a lot of bulbs with cool white LED to save money.Nice setup, the light looks a bit pathetic though. I'd want a huge multi-tier thing! Needs over 2kW worth of filament lamps for best effect.
Could I suggest a visit to the following web site HEREGot to the top floor yesterday, where’s there’s a door, which is locked, and no one knows where the key is….
Link not working.Could I suggest a visit to the following web site HERE
That makes sense. The switch would have a similar operating force either way. Normally one end would be weighted, while the other end would have a weighted float - the weight of the float in air being enough to overcome the counterweight and switch force, but once floating then the counterweight would take control.But here’s the big switch, that I’m going to call a tick-tock switch.
If you can read it, the label does say “float switch”
The milk receiving jar is mounted on a big spring, and as it gets heavy it trips a similar switch to run the pump to empty it. When it's light enough, the switch trips off and the pump stops.
Why do I get the feeling that you are talking through experience hereAnd then you have the Automatic Public Convenience, where the floor switch again was the only occupancy sensor, with the result that if you climbed up and braced yourself between the walls to unload the floor, while opening the door and letting it close again, it would start the cleaning cycle with you inside.
Well the way I'd do it would be ...We had an interesting discussion on another forum about an impulse-based float level transmitter by Gents, e.g. for monitoring the level in a water reservoir, where the receiving equipment was based on normal Pul-Syn-Etic impulse slave movements but with separate solenoids for up and down, operated by impulses of opposite polarity. Every impulse moves the receivers, which could also be drum recorders or limit switches, by so many hundred gallons. The chap had found a level-display slave dial, but not the transmitter. None of us had seen a transmitter, and it became an interesting conjecture how it worked. Some spoke of a 'float switch' but in reality to do its job properly it had to be much more sophisticated than that. I'd like to see one for real.
