nowt wrong with dissing the damaged leg to the socket and making it a spur.
Jeez.
Just do it properly. Its not splitting the ****in atom.
And your justification that this method is a bodge is?...
1.Crimping solid cores with insulated crimps....bad news
2.Heatshrink over joint....not the same standard of insulation...bad news.
3.Wet plaster over a poorly insulated joint in a cable...bad news
4.Potential for future dampness in a wall with a poorly insulated joint...bad news
Just my opinion but nothing anyone can say in support of a crimped joint plastered into a wall will ever change it.
Tel came up with by far the best solution.
wirepuller is correct though
a crimp terminal is ok at the screw block but not for continuing a ckt as surge current could overload it and burnout
twisting the wire ends together and capping with a wire nut mechanically binds them (also taping cap in place)
any junction in the wire is susceptible to corrosion so i usually seal the connection with liquid electrical tape (rubber solution)
chloebear,
gnuuser,
