Discuss Neat doorbell transformer in the UK Electrical Forum area at ElectriciansForums.net
Customer needs a transformer for a new fancy door bell. Current transformer and chime mounted on wall next to door so nice and easy but my question is...
Is there a din rail mounted chime I can put in an enclosure with the new transformer, thus swapping the wall mounted chime and tranny with some sort of low profile/ discrete ish enclosure ?
Reply to Neat doorbell transformer in the UK Electrical Forum area at ElectriciansForums.net
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
Hi, I purchased a Time twin strand bell cable with a rating of 12-30V, 2A, low voltage, not for mains use. I wish to use this for installing our...
Hello All, Incase this reaches other non UK residents to confirm this doorbell has been fitted in England it regard to electricity distribution...
5K
I've bought a ring wired doorbell and I've run in to a spot of bother trying to install it. The transformer is above my connection box in the...
I have a Ring Doorbell which has no Chime, but which is trickle charged via a wall-mounted BG DIN Rail transformer in a Hagar casing which diverts...
