A
ash77ah
Hello there I need to control the speed of a drill for a project. Instead of using the trigger I need to use a dial (like a dimmer switch) to control the speed the motor turns at.
I will be using this drill - Powerbase 550W Hammer Drill from Homebase.co.uk
Will this control unit work?
Dimmer 2500W Kit 220-240VAC Lamp Oven Voltage,Speed, Temperature Regulator | eBay
I plan on replacing the trigger of the drill with this. (I will also be adding an on off switch too) ((If anyone wanted to do me a wiring diagram that would be even better))
Any advise on this will be gretly recived!
Thanks, Ash.
Thanks, Ash.
