For the life of me, i don't understand what the problem is here!! Were talking about bonding conductors. In reality it's no different to having water/gas services tied together by fixings along there length, to a metal framed and clad building. What possible detrimental affect will cable tying a bonding conductor to a service pipe create?? Not saying that it's something i would do over long runs, but within cupboards to neaten up the bonding conductor(s) route, ...i can't see any problem!!
The very last opinion i would take any notice of, is a NICEIC assessor. Probably too used to making up his own rules, like his employers!! lol!!
Time to stir the thread up a little
I posted that there may be a regulation saying that its not permitted
I have found the one I think may reference the question
The section title is Proximity of wiring systems to other services
If the bonding conductor is defined as a wiring system (which I believe it is),then reference to 528.3.3 says to effect, if a plumber carried out a job on the other service (the gas pipe) he is not electrical trained and may damage the electrical wiring service and this is not permitted
The bonding cable is part of the primary safety system,strapping it to a pipe that may be altered,rerouted or generally played with,the safety of the system is put in doubt by the installer using the pipe as support for the cable
At least that is my impression,personally,I don't see any problem doing so,but on the other hand it's good to know what the good book is trying to say,whether it seems sensible or not initially
The above is my interpretation of the regs,I may be getting the wrong end of the stick and am having another blonde moment:angel_smile:
I won't argue the case.that's mainly because I can't and it does seem a little trivial
I always thought the rules for segregation were for CURRENT CARRYING cables - the CPC is a protective conductor and only carries current in fault conditions. Surely then it's ok to have it tied to the gas pipe too as well as water?!
mmm, Common sense again me thinks. Cant see any harm in it as long as the cable ties aren't too tight copper is soft.
This is only my humble opinion though, so it may not be the done thing. Another load of bollox is bonding within 600mm! I would rather bond it somewhere than not at all, once had to bond it 17 feet from point of entry, due to it never having been bonded 30 years ago when the house was built. My justification for this was, 1, that fault current wont take much longer to travel 17 feet than it would to travel 6 inch, and 2, i couldnt get at the bit that enters the building.
Cheers..........Howard
NIC in Snags and Solutions Earthing and Bonding snag 46 quote regs 528.3.3 and 543.3.1 .from BRB I think.
yup definately in the snags and solutions book, interpretation of the actual regs mentioned will be different from spart to spark, another reg where debate can be assured, but it is there as you pointed out
That useful phrase 'reasonably practical' comes into play again!!
I think the point is you using the pipe as support for the cable, you wouldn't run loose on the floor so you'd tack or trunk it.
I think the idea been your attaching a cable to something that's essentially removable.
Not that I see a problem over a short run
I think the idea been your attaching a cable to something that's essentially removable. Or could be altered.
