Discuss Need help with this question in the UK Electrical Forum area at ElectriciansForums.net
Yests as per BS 7671 sequence of testing OSG Page 93, OSG Page 96 Although these sequences also need to be done during the installation, an EICR is done to make sure the installation is safe, how can you be sure that there hasn't been any alterations or tampering by unqualified people, personally I would carry out the tests as per OSG
The simple reason, is that with initial verification, any defects found, are required to be rectified and retested before continuing with the sequence.
An un-rectified defect could affect the rest of the tests in the sequence.
With a periodic inspection, there is no requirement to rectify any defects, and it doesn't matter if a defect affects any number of tests.
Reply to Need help with this question in the UK Electrical Forum area at ElectriciansForums.net
I note that in answer to another EV Charger question a member suggested a 40A breaker would be preferred to a 32A because of many hours at...
Commissioning a busduct. My contractor has installed a 2000amp aluminum Busduct in a 17 floor office tower. The specifications state you should...
Evening all, Just a quick question, I am an electrical maintenance engineer and have 18th edition, inspection and testing and so on, so I get...
Commissioning a busduct. My contractor has installed a 2000amp aluminum Busduct in a 17 floor office tower. The specifications state you...
I have got these questions on 2391-52 inspection and testing but can't remember option of 1st two questions. Please any suggestion will be...
