Discuss Nest 2nd thermostat issue in the DIY Electrical Advice area at ElectriciansForums.net
Hi Guys,
I hope somebody has an answer or a recommendation for another system.
I’ve had a Nest heat link and . As you may know there have been issues with the 2nd gen thermostat. I’ve been in touch with google support but my unit was 2 years 3 months old so no warranty replacement available. The thermostat has stopped connecting to the heat link via WiFi ( I’ve read it might be a software issue). I have to say Google support were useless. My heat link still works and the 2nd gen unit still connects to it via Bluetooth but I no longer have a WiFi connection via Alexa etc. I have lost faith in Google Nest. My question. Is there another thermostat that would connect to the heat link via WiFi or do I need to replace both units to have a workable WiFi system? Any recommendations? I don’t want to try a 3rd gen or nest e- thermostat unless there are no other options. What’s my best way forward? Thanks Alex
Oh dear. Technology is great until there is a hiccup with it. Hopefully someone will be able to offer some advice soon for you.
So, most issues with wifi are due to the security settings not being the same or the wifi settings on the router not being correct.
try turn off the 5Ghz setting on the router.
James, thank you so much for taking the trouble to reply. I believe your suggestion was something Google Nest attempted when I contacted them. I’ve since read a software update was behind the original issue. I think it stopped the unit connecting to the internet. Many others have suffered from the same problem. Nest replaced those within the two year warranty period but mine was 3 months outside. I can’t update the software because the unit doesn’t have WiFi connection. Catch 22. I’m peeved with Google Nest and would prefer another thermostat. I am reluctant to spend another £200 for another Google Nest thermostat. I hope someone can offer another solution. Kind regards Alex
I might be able to swing by in about 10 days time when I am in crick.
I think you are near there?
if I can sort it then you will owe me a beer!
Reactions: DPG
Wow! Thank you. If you can sort it I will buy you a crate! Msg me nearer the time with your ETA and I will give you my address. Once again thanks.
Reactions: DPG
Have sent you my number.
send me a quick text in the week and we can make a plan
Reply to Nest 2nd thermostat issue in the DIY Electrical Advice area at ElectriciansForums.net
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
In July I moved into my new home with Schluter DITRA heated floors in the bathroom. The floor quit working in December, and my GC and a rep from...
