Hi,
Just about to embark on installing a Nest Hello Doorbell. There isn't a doorbell at the moment (no door bell, no doorbell chime although during the renovation cat 6 cable has been laid ), I have got a 8v-24v transformer (https://www.NoLinkingToThis/p/briti...le/8707p#product_additional_details_container).
1. Is it possible to spur from a double socket, to connect the transformer? I would use 2.5mm cable and place the transformer in an enclosure.
2. Is the cat6 cable suitable to run the 16v-24v load to the nest hello doorbell ?(I'm not going to install a doorbell chime as i'm going to use google Home Minis around the house).
3. When connecting the Cat6 cable to the transformer should I cable in pairs ie. 2 cores into live and 2 cores into neutral (or should I use less cores or more?)
4. Can anyone think of anything that I might not have considered?
Thanks for all your help
