Discuss Never heard of a bending spring then in the UK Electrical Forum area at ElectriciansForums.net
Even with the sand it still collapsed!
I worked with a bloke on one trip, he did his time as a maintenance spark, we had loads of PVC tube to install, and he wanted to use a heat gun to bend it, quite put out when I started bending it with a spring.
sand does not whack you in the face though.
Reply to Never heard of a bending spring then in the UK Electrical Forum area at ElectriciansForums.net
I’m an electrician trainee and very new to conduit bending. So the length of the floating wood is 9 1/2” and the height is 10 3/4” I’m doing a...
any body heard from the top commander, Tele not been here for a while . has he smoked his last woodbine and his ashes put in the packet .lol.
I’m looking to buy a Conduit Bender. Does this come with everything...
Would anyone be able to recommend a good 25mm bending spring. I assume there is a difference between say a Marshall Tufflex and a Tower one from...
Bit like those things you see clamped onto a water mains when people add an outside tap. Just a lot more dangerous by the looks of it on the...
