An appliance such as a fan would surely be protected far better by a fuse designed for the protection of appliances? As far as I know BS1361 fuses aren't as good for that as glass/ceramic fuses normally used in small appliances, and they can be sized far more appropriately for the load, a 3A fuse for a load which is likely less than 100W is not so great.
I think we all agree with both you and Eng. The problem for us, however, is that a poor electrician went to prison following a fan fire when he didn't fit a 3A fuse, BS7671 tells us to follow manufacturers instructions (yes, they are British instructions), and even our scheme providers tell us it's something we must do. We all know that a 3A fuse probably wouldn't have helped over a 6A MCB, but they are the rules and we are supposed to comply with them.
Thus we come back to the issue of fitting a 3A fuse in the perm live supply but not having the sw-live protected by the same fuse.
presumably that's because when the switched line is energised, the punter is in the bathroom and would see/smell the problem before he had to run into the street naked, shouting "FIRE".
I don't believe it is possible to rely on a punter's ability to sense impending danger or be equipped with an ounce of sense.
darwin theory in force, then.
Now is that actually 100% a true and accurate statement of account, or another old wives tale that does the rounds every so often?? Any expert witness of good standing can call that statement in a court of law and completely ridicule by actual facts that a 3A BS 1361 fuse cannot and will not protect the manufacturers fan, any better than a standard 6A MCB!! Rules need to be based on facts, and this rule is most definitely NOT!! Now on the other hand, if that fan came with a factory fitted cord/flex rated at 3A or less, ...then you could say you have a bona fide case for a prosecution!! lol!!
think that post is what we can call nail on head. the 6A MCB will most probably trip before the 3A fuse has even thought about it.
post aimed at eng54's post.
What's wrong with comments like that on a public forum? Do we all have to wrap everything in pink fluffy cotton wool to appease the easily offended? You can hear much worse things being said in most pubs.
If you are easily offended don't go reading things which have been posted on a forum largely populated by people employed in the construction industry!
No dave you're right, it shouldn't be all wrapped up and fluffy but it should have a tiny degree of usefullness somewhere within it and this isn't a pub.
Apologies to Currie for straying off the topic.
The thing with an open forum is anyone can view it. Thats why there are private areas to let off steam.
What was offensive about that? I find the idea of draconian censorship to be offensive!
Heated discussion! I for my answer early on in the thread so I am happy not to rcd protect as all wiring and fan isolator in loftspace .
Currie
