- Jun 28, 2007
- 14,782
- 3
- 4,440
- 65,798
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Other
- If other, please explain
- Not an electrician at all.
- Business Name
- Ekthetikos
Please list the tools you'd buy if you started out again and I'll grab the lot in a few months and make a new starters toolbox list topic thing somewhere.
We did a similar thing on the tile forum and it's a good topic for new and experienced (never old!) tradesmen to browse through from time to time.
I'm guessing the list would be slightly different to THIS one by the way?!
_____________________________________________________________________________
hand tools
Irazola screwdrivers
Sidecutters
Long nose pliers
Pliers
Hacksaw
Junior hacksaw
Ratchet crimpers
Knife
Tape measure
Conduit cutters
Re-threading tool
Hammer
Bolster chisel
Floorboard lifter / wrecking bar
Wood chisels
Combination square
Spirit level
Sud detector
Wire Strippers
Strait Line and Chalk
tin snips
fish wire/draw wire/rods
club hammer
marker pen/pencil
torch/headlamp (for them lofts)
tester
socket/martindale
file
spanners
chalk line
boat level
long level
GS38 voltage indicator
Martinadale prooving unit
Cable shears
25mm flat wood bits
Ratchet crimps
Multimeter
Isolation lockout locks
Fibre glass steps
Bending springs
Hole saws
Dimond tip hole cutters 4" & 6" (for extractor fans)
Bolster
Scutch chisel
Masonary bits
Henry hoover
Armeg board cutter
Transport - van
electric wall chaser
tape measure
mobile phone
magnetic screwdriver or magnetic pickup
A good selection of insulation tape
A few meters of Earth Sleeving
A few meters of single core cable
Cable Rod kit - I couldn't live without this
General selection of drill / driver bits and SDS bits
Power tools
A good combi-drill (18v)
Chaser
Vacuum cleaner!!!
Cordless scredriver
Core drill
SDS drill (24/36v)
Cordless circular saw (I prefer to use one for cutting floorboards)
hand tools
Sidecutters
Long nose pliers
Pliers
Hacksaw
Junior hacksaw
Ratchet crimpers
Knife
Tape measure
Conduit cutters
Re-threading tool
Hammer
Bolster chisel
Wood chisels
Combination square
Spirit level
Sud detector
Wire Strippers
tin snips
club hammer
marker pen/pencil
tester
socket/martindale
file
spanners
chalk line
boat level
long level
Cable shears
25mm flat wood bits
Ratchet crimps
Multimeter
Fibre glass steps
Bending springs
Hole saws
Bolster
Scutch chisel
Masonary bits
Henry hoover
Armeg board cutter
Transport - van
tape measure
mobile phone
Power tools
Chaser
Vacuum cleaner!!!
Cordless scredriver
Core drill
SDS drill (24/36v)
