Does anyone no of companies that will manufacture our new patented electrical outlet that will make installing cookers and ovens are far easier job for all concerned.
Regards
Michael
Regards
Michael
Yes meeting with a couple of them at ELEX in Harrogate at the end of AprilHave you tried the normal companies? Hager, proteus, MK, click, BG?
To be frank, installing a cooker or oven is a once in a while job.
It’s not a portable appliance that gets unplugged time and time again.
Is your design a plug and socket combination?
Thanks yes just sent them an email cheers
A quick search brings up THIS and THISDo you have more info about your product? Presumably you should be OK sharing a brief description, since it is protected now.
Always interested to hear new ideas.
It's not a cooker switch. It's an outlet plate with a combined 13 amp socket. Could be useful when connecting a hob and oven to the same outlet.
Yeah but if you use a traditional cooker control unit along with a cable outlet further down the wall then you have means of isolation. With this you don't have that. So what's the advantage?
Cooker outlet plates have never had a built in means of isolation. That would be provided by the cooker switch above the worktop.
The outlet plate goes below the worktop.
Not much other than not having to wire the socket from the outlet plate. (Which is a pain in 6mm²)I know, but what does this offer over a dual back box with an outlet plate and socket fitted in it?
