Discuss New Subpanel with H-Tap Compression connectors in the DIY Electrical Advice area at ElectriciansForums.net
Hello all,
For Quebec Electricians.
I am new to this forum and had a question about installing a new panel.
The previous owner had installed an Aluminum 3/0 2 AWG cable from main panel to the garage.
I would like to install a 100 amp panel in my garage to add additional circuits for my house to install near my garage. The installation will be quicker and easier this way.
I purchased a 100 amp circuit breaker for my main panel but it only supports cables up to 2/0 gauge.
Would the following be legal to install within Quebec:
Main Panel -> 100 Amp circuit Breaker -> 2/0 AWG Aluminum cable 5 ft -> Thermoplastic Junction Box -> H-TAP Compression Connector for 3/0 to 2/0 -> 3/0 2 AWG Cable 60 ft -> Sub Panel Main Breaker if it accepts 3/0 cable or -> Thermoplastic Junction Box -> H-TAP Compression Connector for 3/0 to 2/0 -> 2/0 AWG Aluminum cable 5 ft -> Sub Panel Main Breaker.
Reply to New Subpanel with H-Tap Compression connectors in the DIY Electrical Advice area at ElectriciansForums.net
I have an outbuilding a fair distance from the house. In this outbuilding I just want to have some lights, a small music radio/clock, and a...
Hi, I am burying wire from the outside meter panel to the new 100amp sub panel inside a garage. The run is 20' long. Is 2-2-2 Aluminum URD Cable...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
I want to verify if the breaker size is correct for the service going into my detached garage. I have 6 AWG cable going from my main panel in my...
