Discuss Niceic QS how much responsibility in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Ian1981
Mentor
whats everyone's view on the QS system used?
How much responsibility should a QS have, should they inspect all installation and testing going on within the company they work for and are they the fall guy if something goes wrong.
Would be interested from all the QS guys on here and the non QS as well.
In my mind the QS, as the title suggests, should be supervising. For larger jobs they should regularly be on site overseeing the installation and testing. For smaller jobbing type works they should at least be spot checking their electricians work.
As ever, the employer needs to give their QS's sufficient time and resources to do their job properly.
There is a tick box on the NICEIC annual assessment form to say that the company has a suitable number of QS's. However there's no set ratio of QS to sparks, mates, apprentices etc.
I'm not a QS myself so others who are may have other opinions!
Anthonybragg is the guy to speak to on this subject
At the company I work for, 10% of jobs are spot checked and obviously all the certificates are reviewed before they are signed off, mainly to make sure they're filled out correctly and that there aren't any stupid Zs readings.
I agree with the Coroner in the Emma Shaw case.
The NICEIC QS system is flawed and open to abuse.
That aside, to my mind a QS should know the Electricians they are supervising and should be able to determine which need checking up on and which don't.
I would expect a QS to check every Certificate or report they are signing off on.
Not an expert in this issue so my thoughts may be flawed, from listening to friends the QS system is flawed from top to bottom, my example revolve around a good friend who was a QS his firm was NICEIC registered, he was not given the time to do his job properly, constant references to his signature being forged on certificates, the firm was only playing lip service to the rules, my friend eventually left, couldn't stand the abuse any more, the NICEIC eventually told them to do one and revoked their membership basically I think the firm was using their registration as a means to get more work, rather than producing good work. Not sure if the NICEIC was aware of what was going on at the time.
I wonder how many employers are aware of the scope in which a QS needs to do their job as a few I know are always working on the tools as well.
It seems you need 100% backing from your employer so you can live up to the role as it where.
Thanks for the input.
The trouble with the company I work for is that the people in the office that issue the work to the "engineers" don't have a clue and only care about getting jobs done on time so they can get their poxy £30 bonus. This means that they send the wrong person to the job who more often than not don't bother to do any sort of testing or certification. The QS isn't even aware of what jobs the idiots in the office are handing out. Therefore if there's no certificate to review then how can they go and do a spot check on their work?
Sounds like a 'start as you mean to go on' job and don't be bullied into changing your job role 2 months in. That advert IS how a QS should be doing the work and let's face it, they are not going to be twiddling thumbs waiting for stuff to do. All the best to Westway for having it down in writing as 'evidence'!
Reply to Niceic QS how much responsibility in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
NAPIT Certification Scheme NAPIT with more than one operative
Hi Guys Hope this is in the right place... I have recently joined NAPIT and had my assessment. We are a limited company of two qualified...
As a non-electrician (I make the tea in the forum imaginary office, I think the tea is real though) I wonder, is there a way to avoid a...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
I got a TEXT message (i dont know them and i cant find out who they are from the phone number) "Hi speaking from Indeed Are you available to give...
NICEIC Certification Scheme NICEIC renewal assessment debacle!
Hi All, I recently had my NICEIC renewal assessment. We are a two man band. We only carry out small local work and we are approved contractors &...
6K
