Discuss NIMh ENd of chrage detection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
borisgazza
i am intersted in the end of charge detection(-deltaV) on some NIMH chargers, i would like to test that effect on some chargers.
I got some chargers(like GP Smart power bank, GP H500,etc...),all the chargers i have use the drop of voltage as end of charge detection, so what i did is, I connected in serie to a battery a low ohmic resistance, i initiate the charge and after i while a short the resistor ,so drop of voltage but none of the charger did react to that drop,i manage to get a drop of 0.1V but still none of the charger i worked with reacted to that drop, so i would like to know if there are more criteria that i have to take in consideration to generate that drop?
Reply to NIMh ENd of chrage detection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi. Not sure if it's the right place to ask, so won't be upset if it gets removed. Apologies if the terminology (PEN/PME/etc) is used...
7K
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
Hi, I have question about paralallel discharging NiMH modules. I have 40 modules and one modul consist of 6 x 1.2V cell = So nominal capacity is...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
