Hahaha, sorry Westward I left. that bit out ... Lack off cps in the drops themselvesWith regard to what?
I missed out the NO .. so the question should be what's the general opinion of domestic switch drops with no CPCWhat do you mean by 'what's the position'?
The question doesn't really make sense, do you want to know people's opinions on what should be done, what can be done, how to mitigate the risks, how the regulations apply, how to explain the dangers to a customer or something else?
No cpc in the switch dropWith regard to what?
This is proving harder than finding hens teeth..What would you do if you came across this situation??I gathered that but in what context?
I'm afraid I'm on @westward10 's side. It's not clear to me what exactly you are asking.This is proving harder than finding hens teeth..What would you do if you came across this situation??
All cables should have a CPC in multi core cables, so rewiring is the only option, another option would be to disconnect and use the switch receivers module wireless switches.What's the position on lighting drops with CPC ?
If. you came across a dwelling with no cps in the switchdrops what would you advise the customerI'm afraid I'm on @westward10 's side. It's not clear to me what exactly you are asking.
