Discuss No flash on iPad in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
So they can release a new one with a flash in 6 months and all the Apple fans will go crazy over it...
Apple always do the same...like with the iPhone slowly releasing old technology on the phone but people go wild over it...like a camera, Bluetooth etc...
Sent from my Xperia S using next doors WIFI.
Interesting article - I always believed that the reason Flash was not used by apple was because of a fall out between the two companies. Makes sense though:
"But the mobile era is about low power devices, touch interfaces and open web standards – all areas where Flash falls short."
Flash does use a lot of power and is not really compatible with touch screens.
Reply to No flash on iPad in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Currently using paper job sheets. Does anyone use an app or alternative. Looking to give my employees an iPad and send jobs that way. Would it be...
New batteries ... There is a dimmer attached to the light circuit . Full power its fine .turn down , light flashes , volt meter LEDS dance up and...
Hi all, any advice would be greatly appreciated. Went to do some work at a factory unit on Monday ( changed 20 florries to LED battens and changed...
I have just bought a new fancy van as the old renault trafic had done 213,000 miles and needed a rest. The new van is a 1.5L Citroen Berlingo...
