R
Try using this diagram when building your setup
I'm not sure that will be much help to him if he is using twin and earth cable
Eh?
Nowt wrong with that.
Need some brown sleeving.
That's the sort of diagram i would expect to see if using singles in conduit. If using t+e and 3 core, I would generally have the feed and switch wire at the same switch, that's all I meant.
It doesn't have to be massive, the socket is to power the rig. Rather than going to any huge expense though draw a simple lighting circuit, one feed one light one switch. Then draw an extra terminal on the switch to make it a 2 way and another 2 way switch, then with coloured pens draw how you're going to connect them and make it work using 3 core cable.how big do you think the board will need to be if I built what snowball sugessted
and whats the 13am rcd protected socket for
Teach youself how to, today-- 2Way circuits, including inters;
Shopping (scavenging) list;
Piece of plywood
A couple of 2 way switches
A couple of intermediate switches.
A couple 2 gang 2 way switches
Suitable back boxes.
Couple of battern lampholders and lamps.
A few scraps of T&E
A few scraps of 3 core & E
RCD protected socket and 13amp plug with 3amp fuse.
TEST EQUIPMENT
Teach yourself starts here, work out what the above is for then use it.
