Try using this diagram when building your setup
It sounds like you have 2 circuits at the dining room, if you really must do this knock everything off and swap the switches over. A word to the wise though, if my son did this he'd be invited to an --- kicking party, also remember you have no way of proving earth continuity on anything you're doing so ask yourself is it wise to do it.
Eh?
Nowt wrong with that.
Need some brown sleeving.
That's the sort of diagram i would expect to see if using singles in conduit. If using t+e and 3 core, I would generally have the feed and switch wire at the same switch, that's all I meant.
how big do you think the board will need to be if I built what snowball sugessted
and whats the 13am rcd protected socket for
Aye, see what you mean. I usually do the 3 core way.
He'll have to get some 3 core now! :-)
It doesn't have to be massive, the socket is to power the rig. Rather than going to any huge expense though draw a simple lighting circuit, one feed one light one switch. Then draw an extra terminal on the switch to make it a 2 way and another 2 way switch, then with coloured pens draw how you're going to connect them and make it work using 3 core cable.
When you've drawn that out and understood it turn the page over and you're going to draw out exactly the same but adding an intermediate. The connections are shown in Ryan's sketch above.
When you've got all that straight then build your rig.
Tony Way
I have had lots of calls like that and as hard as i try to explain where they have gone wrong they just do not get it. Also i had a guy call me when he changed a 1 gang 2 way switch used as a 1 way and he put the earth in the spare terminal on the switch and could not make out why he kept tripping the mcb. It,s only simple if you know what you are doing
Teach youself how to, today-- 2Way circuits, including inters;
Shopping (scavenging) list;
Piece of plywood
A couple of 2 way switches
A couple of intermediate switches.
A couple 2 gang 2 way switches
Suitable back boxes.
Couple of battern lampholders and lamps.
A few scraps of T&E
A few scraps of 3 core & E
RCD protected socket and 13amp plug with 3amp fuse.
TEST EQUIPMENT
Teach yourself starts here, work out what the above is for then use it.
Right I'm in screwfix now the rcd protected socket is 60 quid so think I might just plug it into the wall?? In regards to the intermediate switches is it a 1 g intermediate switch I'm after as that's all I can find in here and for the 2 way switches am I after a 2 gang 2 way or a one gang 2 way please
One gang 2 way switches and pattresses to suit, 1 gang intermediate with back box, and use a plug in rcd adapter for power tools or garden equipment
