Search the forum,
Discuss Not such good tray work. in the UK Electrical Forum area at ElectriciansForums.net
High Tower
So working in. Shopping centre and admiring the awfull tray work in the carpark.
Look what I found, this is the 11kv tri for the TX. Nice!!, think its safe to say that in this case the tray bond was required.
The cable istallation is bloody terrible!!
they should be securely cleated and if triplex is used, special cleats are available, that maintain the twist of the trefoil.
id be ashamed to leave that!
Oh the cleats are up there but only maintaining the tri. It's just lying on the tray not even bothered with zip ties
It would have taken longer to put the earth link on than it would have done to cut the flange and bolt the two trays together. :frown:
Ive seen worse M8 TBH, it isn't great admittedly, but not a gasp situation IMO, although a rough Job.
Totally down to the site supervision, both from the contractors themselves, and the clients supervision!! Or should i say the LACK of it!!! lol!! The installation as shown, is a potential disaster waiting to happen to be honest!!
The worrying point of this installation for the 11KV cables, is that MV cables don't like any areas of ''point pressure''. It can/will over time create a weakness at that point, where the higher voltage can penetrate the insulation to the semi conductive layer and on to the copper screening foils/tapes and beyond!! Seen this phenomena with MV/HV cables a good few times before. The problem is not so much the metal tray slightly penetrating the PVC over-sheath, it's the voltage trying to break through any weakness in the boundaries put in place to contain that voltage!! It's not as simple as your normal LV cable situations!!
That's terible a nice gusset bend in there would have done the trick. Bet the cable was short when it was pulled in and they've done that to gain a few inches lol.
Ok now I'm going to tell you that that is a shopping centre car park, the trays are on the ceiling and can easily be touched as the trays are only about 6'6" off the floor, very low ceiling indeed.
Should be nicely formed in that tray with tray lids. Yeeeeehaaaa
To be honest it looks like it's buckled or they've half arsed tried to bend the side.
But the bottom one has definitely been hit
I also think someone might have driven or reversed a vehicle into it. It's difficult to say without seeing it from further away but the height changes on the right hand tray don't make sense even as a cowboy install job..
looking at that, I would say that the tray has most likely been put in by some underpaid labourer who wasn't interested, they have put this in before the steel work was even finished hence the jotum spraypaint all over it, then they probably got paid off during the usual agency rotations, the job was probably behind on the concrete or something similar......the cable pullers have been in and pulled it over the tray with a few cable ties to get it to turn in the way they wanted it, they would have been in and out as fast as possible, then the steelwork got finished and sprayed white, going onto the tray and cables at the same time...
you can see it was done fast and untidy, the screwed rods are all odd sizes etc...and the ends are bent where somebody has been shoving an alloy tower about to put the cables on there....
Reply to Not such good tray work. in the UK Electrical Forum area at ElectriciansForums.net
Last weekend I experienced a weird electrical fault with my 2010 Peugeot Boxer Van. A little background - the van is a 2010 Boxer 330 2.2 Short...
So I have tried applying to every electrician mate/improver jobs there is on every job websites and I got a few calls saying that they want guys...
NICEIC Certification Scheme Getting accredited to
Looking for some advice regarding joining a CPS. I've been in the electrical industry in various roles for nearly 10 years. I started my...
Hi, I am 17 years old and my main goal was to become an electrician. But I have been hearing from people that becoming a gas safety technician...
