Discuss Not Sure what too do in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
petal spark
Doing a rewire at the moment. There are 2 boards, 1 is feed from the other. The main one has a 84amp RCD, and the one it feeds is a 64amp fuse, all this is from a 100 amp main fuse. now there is an isolator that comes off from "somewhere". Now the client wants me to change the Isolator for a 4 way Dis Board, so that i can feed a 3 phase supply to a 500w compressor and some small power and lighting... Now what size mains isolator would i get away.. he has been told a 125amp... I think that a 100a would be better... ps its a job i really dont wanna do, well out of my comfort zone.:confused::confused::confused:
Hi there
i must agree with sparkyt
do not put your self at risk get another sparky to help you
is your incoming supply a three phase supply had to ask did not seem clear where the board is being fed from
isolators are there for a reason not as a distribution board:eek::eek:
cheerss
your descriptions sound weird.try and send us some photos(preferably of you lying at the beach while you get someone else to do the job)
Reply to Not Sure what too do in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
From another thread: I'm thinking about this and it's got me all confuzzled. Don't fuses protect anything downstream ie my laptop's charger...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
