Discuss nothing like being thrown a curve ball in the UK Electrical Forum area at ElectriciansForums.net
I was asked to change a light fitting in a neighbours house easy job help out a neighbour I thought. I had my 2nd oldest son with me so thought it would be good to show him how to work safely ie how to use a voltage indicator and work safe.
normal procedure
prove indicator using proving unit
check voltage at light fitting
demonstrate fitting dead (lock mcb off)
prove indicator with proving unit
get young lad to disconnect light and he said I've just had a shock from wiring (single twin and earth at light ) I thought I just checked and its dead so I checked it again and no voltage so I decided to do it. I got a cracker of a shock made me look like a total plank in front of young lad so I checked again, no voltage between L+N but 240 between L+E.
turns out when there smart meter fitted the installer made a small mistake (don't know how to find sarcastic emoji)
turns out the MCB switched the neutral as L+N reversed
anyone else had something like this
and DNO contacted to rectify issue
Doh !
I have only once followed safe isolation procedure and ended up with live parts, so it is not an infallible method at all.
In this instance though you just did it wrong.
There is another thread on there about a new 'smart meter' being wired up wrong.
Surely there is some sort of action people can take in this situation of you hadn't have spotted that then nothing would have had proper protection for God knows how long I think it's ridiculous I've heard of this happening a few times now
So what about safe isolation for a distribution board change, how many people would test all the outgoing cables as well as the incoming supply?
I changed a board on Tuesday where one of the outgoing lighting cables was still live after isolating the board. Powered from another board, we think cross connected during some recent building work.
I know people hate volt sticks but I always use mine on cables that I have already proved to be dead. I just see it as an extra line of defence and in fairness it would have detected the voltage in the cross polarity in the OP's scenario and also the live outgoing circuit in the second scenario.
Volt sticks are very useful when used correctly.
Ha ha ha - must be Plumbers revenge !
Makes you wonder how many of these there are out there waiting to catch people out.
Reply to nothing like being thrown a curve ball in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
