Discuss Nuisance tripping. in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
I’ve just completed a large house re/ new wire with new 15 circuit split MK board.
Test is fine but have low IR on some circuits, board randomly trips rcd on one side no pattern.
Its a big house lots of tech plugged in etc, so I’m thinking update from B to C type mcbs Incase it’s an inrush issue on one of the circuits but I’m open to suggestions???
Thanks .
It’s hard to say as they have a lot of hard wired equipment I can’t get at, boiler, fridge Frezzer, etc, I’ve told them it’s something they have connected to the circuits or plugged in that they need to eliminate
How can you tell 'them' that when you have done little I&T to establish the fault - from what you have said so far? Possibly is an appliance or combination but more work needed to identify this?
Why do you think 8.8Mohm IR could be having an effect on this? Have you calculated the leakage current that will flow due to this value?
Hi, no I don’t thing it’s an issue I was just giving the details about the test. No I’ve not calculated the earth leakage, I’m fairly new to this so I know far from everything and hope to pick up on the knowledge from this forums.
You should invest in an earth leakage clamp, most wholesalers will have them in.
You must have unplugged everything when you done your IR tests? Or that lower reading could be misleading.
If it is earth leakage then do away with the upfront RCD and change MCBs to RCBOS
Or if you get a clamp you could possibly juggle things round in the board
It would be unusual for a domestic to have inrush currents that would justify type C RCD. Also you might find it harder to meet disconnection times with a type C. If everything is unplugged does it trip? I am not sure whether you mean you re-wired the whole house or part of it? If it is a new rewire then the IR readings you are getting are unusually low for new cables installed properly.
Reply to Nuisance tripping. in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Gone to look at a intermittent ground floor sockets fault today, the RCBO was tripping at random times with no pattern. Nailed down a...
Ring main was on a c40 rcbo so I tested the circuit everything was fine and dropped down onto a b32, It’s quite a long circuit but only serves...
So was on a call out today and cooker circuit kept tripping the RCD. Disconnected at the board and at the cooker switch and IR’d the cable and...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
