Discuss odd demand from building company in the Central Heating Systems area at ElectriciansForums.net
Doomed
New build houses, full system boilers with the big cylinders with seperate thermal cut out and temperature probe which come with a pre fitted link connecting them.
Have been told to remove this link and feed the main live feed for the whole system through it (after the fused switch spur) so if the safety temperature on the tank cuts out all power to the boiler sysem and controls is cut.
Was told its new safety rules - anyone else had this?
(still have the extra valve safety for a fully pressurised system as well as the 3 port)
It seems overkill to me but not entirely unreadable as it does make it more obvious that a fault has occurred.
What does seem daft to me is installing an unvented cylinder with a 3 port valve. Yes it has the additional 2 port val e fit safety but you’d defeats any advantage of fitting a Y plan system.
I haven't seen new builds done for a long time in Y plan, the heating is generally split into two zones on the smaller builds so all S Plan.
What is the need of having a 3 port valve in this setup? Surely 2 2 port valves would be better and more economical?
Is there still a cut out in line with the cylinder stat that operates the 2 port safety valve?
Only wired one Y plan with this system 25 years ago. who has told you to wire these this way?
I think I would contact the manufacturer of the system before making any changes to their wiring.
It may be that there are new safety rules that require this, or it may just be someone in the office thinks it’s a good idea.
Reply to odd demand from building company in the Central Heating Systems area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hi All. Its been ages since I have been on here- Fortunately log in details stored on PC. I have just had a new boiler and 210 ltr unvented tank...
hi need help with wiring this. basically new build with combi boiler, unvented cylinder with dual channel hive ive attached pics with the wiring...
6K
So Dad's Old condensate pump went kaput (screeching like a banshee, float valve sticking and wouldn't shut off due to said sticky float valve but...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
