Well i have just tried to lol to keep some fussy people happy :lol:
What I was thinking about was the pump over run return , I was asking what wiring goes to the boiler . It may have a permanent live , switched live for the boiler, neutral and a pump return for over run , if not then above is goodi
That last one I posted wont work because if Y plan 1 is not calling for heat then the boiler won't fire even if Y plan 2 is.
So I think the boiler needs a dedicated supply like this switched through both relays.
Sintra, I'm pretty sure your penultimate diagram was where I got to before chucking in the towel and coming to the conclusion that all the control needs to be in the same circuit or as you suggest the boiler goes on its own circuit which will be a lot easier to achieve at the end of the day. Unless anyone else has any bright ideas i will inform the customer this is what needs doing.
Sintra, Ray many thanks. This is such a useful site for a sole operator, when sometimes you just cant see the wood for the trees and need a little confirmation from others
cheers
