Discuss Online cert circuit numbers? in the UK Electrical Forum area at ElectriciansForums.net
i think he means the RCD's on the dual board are occupying 5+6 and 9+10,
he could be reading it the wrong way round and it is 1+2 and 6+7 if he's put a 6way in,
but the labels that come with it should make that clear, i don't use online cert so i'm of no use
Crow11 is correct the board labels run from main switch to the left 4 mcbs then i have 1st rcd at position 5and 6.
When i create the circuit details on the cert if paper i would mark those positions as rcd with limited details. Not sure how it's done with online system
if you have 10 "positions" in the CU and 2 RCDs, then that means you have 6 circuit ways. you label the circuit MCBs as 1 - 6. e.g 3 on RCD1 as 1 - 3 ans 3 0n RCD2 as 4 - 6.
you can usually re-label them. spare stickers come with new CU.
Reply to Online cert circuit numbers? in the UK Electrical Forum area at ElectriciansForums.net
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
I got a TEXT message (i dont know them and i cant find out who they are from the phone number) "Hi speaking from Indeed Are you available to give...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi all, Been asked to quote an EICR on a fairly large installation. Approx. 400 circuits that are a mixture of single and 3 phase. This is across...
