G
glasgospark
new house recently built
garden lights outback , swa running from fused spur outside and for about 1 meter its in the ground drainage is this ok ?
is it buried deep enough? is it glanded properly using CW glands? test results OK?
Nothing wrong with it really - just who the hell does that.
I'll tell you who, a lazy c*** who can't be arsed to dig 600mm.
if it is rcd protected does it still have to be 600mm as its not much different from a cable in a wall at 50mm or less
