Discuss ouside lights in the UK Electrical Forum area at ElectriciansForums.net
G
glasgospark
new house recently built
garden lights outback , swa running from fused spur outside and for about 1 meter its in the ground drainage is this ok ?
is it buried deep enough? is it glanded properly using CW glands? test results OK?
Reply to ouside lights in the UK Electrical Forum area at ElectriciansForums.net
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
I've had a search, and found an old thread from 2016... but was wondering about modern views on this situation. I've come into possession of...
Currently I have a Henley block which has 2 consumer units. 1 of these CU feeds a garden supply and garage. Out in the garden which is fed by a...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
