S
scott 123
customer wants outside light ..am i right in thinking i can take a spur from back of socket as long as a use a3A fused switch ? and what would you charge socket approx 3m from where light is going
3m trunking from socket to fused switch trunking 1/2 m up drill through outside wall fit light ..customer has already brought light ...price to install,supply cable, switch,and trunking
he meant to check and ensure main bonding to water and gas etc. if that's OK, then i'd charge half a day's labour at your hourly rate + materials.
RCD? If you are adapting a socket circuit domestically then I would make sure a RCD is fitted?
why? his cabling is in trunking and it's for a light. no requirement to fit RCD protection.
forgiven....... just this once, mind. next time you win an hour in the naughty corner.
get some beers down yer neck. soon be sorted.
