Search for tools and product advice,
Discuss Outdoor Lighting and PIR in the UK Electrical Forum area at ElectriciansForums.net
J
Jay1985
Hi guys,
Just need some advice.
I want to add a couple of security lights to the front of the house off one PIR. I have a porch ceiling light which I want to 'tap in to' to supply the power. Is this possible? If so, how would I do it?
The issue I am thinking is that the power to the outdoor lights will only work if the porch light is on, is that correct?
Any advice would be much appreciated.
Cheers
Jay.
It is your light, how could anyone else know without even a photo of the wiring.
I tend to switch feed downstairs lighting (in which case the answer would be no) and 3 plate when there is access above from an attic (in which case the answer would be yes)
I think it is fed via the switch, I haven't seen any JBs around the house in the lighting circuit.
That is probably because they will be above the ceiling hidden away, I would personally take lee's advice and get a local Electrician in to do the job safely, If you offer up your location there may be a member that is close by and willing to give you a quote.
Reply to Outdoor Lighting and PIR in the UK Electrical Forum area at ElectriciansForums.net
Good morning guys Was looking for advice with regards to installing an outdoor consumer unit. Customer is looking for power to be installed from...
Im just curious as to peoples thoughts on the following install I seen on a video from an Electrical firm today and they did the following: Ran...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi there I am getting someone in to change an outdoor switch and outdoor wall light (like for like). The old switch and light was covered by a...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
