B
bramfield33
Hi. I want to put a floodlight with PIR outside. The light will be powered from a fused plug plugged into an internal plug socket. The cable will run through an external wall. There will be approx 1m of surface run cable outside. What size/type of cable do I need? The spec for the light is 240v. 800 Lumen. 10w. IP44. Integrated LED.
Ideally it should be black but something like this, 0.75 a size down from this will also do the job.
