G
GLENNSPARK
this is exacty what it is DThey're not courses mate, they are introductory tasters to the trade. A 'course' is three years at college minimum.
The worrying thing is he would have just dived in and put the light in. No mention of basic checks/tests first....This thread may seem harsh to the outside world.
But some people just need to be told straight whether the OP likes it or not, he's not an electrician no matter how much he thinks he is.
i`m gettin fed up with know-knowts mark that just carry rite on.....This thread may seem harsh to the outside world.
he wont know how to ring n gland a bit of armoured....If it's going outside into the garden, which is a special location under the regs and Part P, and being run from an existing circuit it will require a minor works certificate and notification to building control - because it's in a special location. Whoever notifies the work should be Part P registered.
To fulfill the requirements the light must be 30mA RCD protected and earthing and bonding should be to the current requirement of BS7671:2008(2011). SWA burried in the ground should be to a depth of 600mm where anyone may be likely to dig, with a warning lable approx 150mm above it. Ideally the cable should be laid on a bed of sand and also covered over with sand before backfilling. If the cable is going under hard standing ground (patios, paving slabs, concrete, tarmac etc) it is reasonable to reduce this measurement to 300mm. If you are connecting to an existing socket circuit that is not RCD protected I would use an RCD spur switch with a 3 amp fuse and run the cable through the wall into a Wiska box. (Make sure the cable is protected by if it crosses the cavity.) Terminate the twin and earth with the SWA there and don't forget the earth link and the banjo. It's easier than taking the SWA into the house. Also drill the drain hole in the box where it is marked otherwise damp may collect there.
If your circuit you are connecting to is already RCD protected then do exactly the same, just use a normal DP spur switch with a 3 amp fuse.
Good luck
Not any more it doesn't!!If it's going outside into the garden, which is a special location under the regs and Part P, and being run from an existing circuit it will require a minor works certificate and notification to building control - because it's in a special location.
but to attempt install....without knowin about earthin n bondin.....lolffs
If it's any consolation guys I recently found out there's a short course route into the gas and heating thing. I know a guy who did it.
oh for gods sake Trev...lol..If it's any consolation guys I recently found out there's a short course route into the gas and heating thing. I know a guy who did it.
