hello all
so sorry as it must be very confusing
the old CU in photo i want changed
i mean running a 16mm twin & earth from main CU to garage CU at rear of house (no garage involved !)
I have no intentions of connecting this cable but just want to incase in trucking from the main CU and run to rear CU unit
its just what the smaller CU are called the GARAGE CU
is going to be installed at rear of house indoors look at photo and video
3rd week now not one electrician interested ! When will they be back could be waiting weeks months would photos of the garden help in maters? Oh perhaps a video?
just thought that i could do all the donkey work now with some help from this forum very glad of your reply's i normally get all my stuff from screwfix
what about this item for the lights connections ? or are they better ones out there YOU ALL KNOW BEST
if I buy the resin ones or gel ? are they able to be tested after fitting
Teebox IP67 Mini T-Junction with Terminal Strip - https://www.screwfix.com/p/teebox-ip67-mini-t-junction-with-terminal-strip/72715?_requestid=824560
these sockets good ?
best to attach to posts
LAP IP66 13A 2-Gang DP Weatherproof Outdoor Switched Socket - https://www.screwfix.com/p/lap-ip66-13a-2-gang-dp-weatherproof-outdoor-switched-socket/30139
I would assume these glands are for the swa 1.5mm 3 core light cable
Would these glands need to fitted at every exit of the swa cable
And at light fitting ? would these tee`s all ready have them built in to the tee units ?
Tauras External Brass 20S Gland Kit with Earthing Nut 2 Pack - https://www.screwfix.com/p/tauras-external-brass-20s-gland-kit-with-earthing-nut-2-pack/82136
and these for the swa 2.5mm 3 core socket cable
Tauras External Brass 20 Gland Kit with Earthing Nut 2 Pack - https://www.screwfix.com/p/tauras-external-brass-20-gland-kit-with-earthing-nut-2-pack/82167
when these electricians get back to work they are all going to inundated with work !
more advice would be grateful Paul
have any one got any recommendations what are the best ones to buy
i have a TLC CLOSE TO ME AND CEF
thanks paul
would help if we knew which part of wales. one of us may be close to you and be prepared to take on the job.
Swansea but who will turn up !!!!
what cost to fit new CU MAIN
and cost to fit second garage CU at rear of house
close guess will do ?
i`m hoping around the £400 mark !
what about the testing and a certificate at the end of it ?
thanks Paul
thanks Paul
Do you want it lasooed in by a cowboy or done properly?
thanks Paul
Hi Paul, I’m pretty close to you I live Cynon valley. I’d be happy to firstly have a look at job rather than giving quote right now and go from there all consumer unit changes have to be tested and certified anyway so don’t worry about that all in with price
[automerge]1595974877[/automerge]
My advice to you is to get a couple of quotations and go from there never settle for the first one unless you know and trust them. Plenty of sparks down swansea I’ve worked with a load of them ?
davesparks i say this as i have contacted lost track now over 8 or is it 9 not one reply
4th week now !
grant i`ll be happy for you to take a look at job
how do i send you a private message ?
nothing as yet
Hia Paul, sorry I’ve not been allowed to post on here for some reason wudn allow me for last few days. Have no idea why. Are you able to wait a few weeks I’ll cut it short, I’m really busy atm and you are a bit further than I would normally do work. I can pass you over to couple of other sparks I know but don’t understand why you can’t get one from Swansea?
hi grant thats ok
this is why ive posted here for help in doing some of the work or it will never get done
i`m up to 10 electricians now one in cadle where we live !!!!!
3/4 th week all around Swansea not one relpy !!!
the last thing i want to do is all the work myself then thou the switch on and boom the whole street goes out !!!!! only joking
but hope all of you in this forum can see what i`m taking about i need to get on with the patio now but cant just waiting on a electrician to say carry on encase i need to bury cables if your back in work grant what the the 10 + i have contacted
i don`t know what i can do more
Strange that you've been let down by so many people.
