R
Rampantchilli
DK- the basis of your arguement is the use of a fusing factor mate (1.45).
Firstly I'm not using fuses and second I'm not supplying machines with high starting currents, just general purpose socket outlets.
Can you now see why the IET get on my ----.
i keep out of these as much as i can as i cant express myself clearly with the written word, but
BOLL*CKS
how can you take all this information, that the IET has supplied, use graphs that the IET have supplied, and use calculations that the IET advise, and apply them wrongly, then blame the IET.?
if you dont like the IET, dont follow it, do your own research, make up your own understandable regs based on YOUR research results, because as you know BS7671 is not mandatory.
and if the worst happens and you go to court you can produce your own regs in evidence, if researched correctly, youll not have a problem.
when i first saw this thread i did a quick calculation on a basic 6a lighting circuit, using your method, and we would all be wiring in 4mm
